The D4 display describes searches of LNKLST library directories, as opposed to BLDL/FIND requests. See the section D2: BLDL/FIND Request Activity in this chapter for information on the difference between library directory searches and BLDL/FIND requests.
The following screen illustrates a sample D4 display.
PMO 4.4 ( Active ) Sys=IPOX 13NOV10:09:10:50 PMO Active Time=5.500 hrs
D4 LNKLST Library Searches - Detail for Set IPL Total Elap Time Library Name Volser Searches Savings 1 SYS1.LINKLIB RESCXA 118,119 3.51H ********* Fnd Nfnd Avg ET Managed List 8% 91% 0.000061S LLA 0% 0% 0.000000S I/O 0% 0% 0.107981S 2 IPOX3.LINKLIB SYSB11 108,229 16.49M S E ********* Fnd Nfnd Avg ET Managed List 91% 8% 0.000031S LLA 0% 0% 0.000000S I/O 0% 0% 0.009222S 3 SYS1.CMDLIB RESCXA 9,421 3.22M ********* Fnd Nfnd Avg ET Managed List 55% 40% 0.000150S LLA 0% 0% 0.000000S I/O 0% 0% 0.021684S
The primary headings on the D4 display are described in the following:
The name of the library. The number to the left of the name is also shown in the LIB column of the D1 display. An index may precede the library name on the ********** line:
You specified the EXCLLNK parameter or the F PMO,EXCLLNK command to exclude the library from the managed list, or you specified INCLLNK parameter statements, but did not code this library on any of those statements.
This library is a PDSE-type library.
This library has been suspended from refreshes.
The serial number of the volume that contains the library.
All searches against this library since CA PMO became active.
The elapsed time that the managed list saved on directory searches of LNKLST libraries. For more information, see the description of Elap Time Savings earlier in this chapter. If you see three asterisks (***), CA PMO did not save any elapsed time.
The secondary headings on the D4 display are described in the following:
The percentage of searches in which the member was found.
To estimate the number of these searches, multiply this percentage by the number of total searches and divide the result by 100. For information on how CA PMO counts and categorizes searches, see the discussion of the Count column heading earlier in this chapter.
The percentage of searches in which the member was not found. This value is displayed only if LLA is inactive.
To estimate the number of these searches, multiply this percentage by the number of total searches, and divide the result by 100. For information on how CA PMO counts and categorizes searches, see the discussion of the Count column heading earlier in this chapter.
The average time needed to resolve a directory search for this library. For more information on this topic, see the discussion of the Avg Elap Time field earlier in this chapter.
The row headings on the D4 display are described in the following list:
Searches of LNKLST library directories that the managed list resolved.
Searches of LNKLST library directories that LLA resolved.
Searches of LNKLST library directories resolved by DASD I/O.
Copyright © 2011 CA.
