Previous Topic: D2: BLDL/FIND Request ActivityNext Topic: D4: LNKLST Library Searches – Detailed
D3: LNKLST Library Searches – Summary
The D3 display shows statistics on searches of LNKLST library directories. This display does not describe BLDL/FIND requests. For information on the difference between BLDL/FIND requests and library directory searches, see the section D2: BLDL/FIND Request Activity.
The following screen shows a sample D3 display:
PMO 4.4 ( Active ) Sys=IPOX 13NOV10:09:10:50 PMO Active Time=5.500 hrs D3 LNKLST Library Searches - Summary of All Sets % of Avg Elap Elap Time Count Total Time Savings LNKLST Library Searches = 294,203 100 0.000931S 2.78H Managed List = 286,770 97 0.000048S 2.78H Member Found = 116,630 40 1.13H Member Not Found = 170,140 58 1.65H Library Lookaside (LLA) = 0 0 0.000000S Member Found = 0 0 Member Not Found = 0 0 I/O Library Searches = 7,433 3 0.034989S Member Found = 725 0 Member Not Found = 6,708 2
Row Headings
The row headings on the D3 display are described in the following:
All searches of LNKLST library directories.
Managed List
Searches of LNKLST library directories that the managed list resolved.
Member Found
Searches of LNKLST library directories in which the member was found.
Member Not Found
Searches of LNKLST library directories in which the member was not found. For information on how CA PMO calculates this field, see the discussion of the Count column heading in the following section.
LNKLST searches that were resolved by Library Lookaside (LLA).
An asterisk (*) in this field indicates that you excluded one or more LNKLST libraries from the managed list. If you see an asterisk, it may represent LNKLST libraries that you did not code on the INCLLNK parameter.
Otherwise, the asterisk indicates that you specified the EXCLLNK parameter or the F PMO,EXCLLNK command to exclude one or more libraries from CA PMO management. The D4 display shows the names of the excluded libraries.
LNKLST searches resolved by DASD I/O.
An asterisk (*) in this field indicates that you specified the EXCLLNK parameter or the F PMO,EXCLLNK command to exclude one or more libraries from the managed list. The D4 display shows the names of the excluded libraries.
Note: When you exclude LNKLST libraries, you reduce the percentage of LNKLST searches that CA PMO can resolve.
Column Headings
The column headings on the D3 display are described in the following sections.
Count
There are differences in the way CA PMO calculates the statistics depending on whether LLA is active on the system or not. If LLA is not active, CA PMO counts a member as found or not found by the following method:
  • CA PMO adds one to the Member Found count for the first library in the concatenation that contains the member.
  • CA PMO adds one to the Member Not Found count for each library in the concatenation preceding the one that contains the member.
  • If CA PMO does not find the member, it adds one to the Member Not Found count for each library in the concatenation.
  • If CA PMO does not find the member, but it does find an entry created with the parameter RETNF=YES, it adds one to the Member Not Found count of the managed list for each library in the concatenation. This eliminates DASD I/O for members that do not exist.
The following table shows how CA PMO breaks down a BLDL/FIND request against the following LNKLST concatenation:
LNKLST library 1= SYS1.LIB1
LNKLST library 2= SYS1.LIB2
LNKLST library 3= SYS1.LIB3
CA PMO searches a concatenation in the order in which the libraries are listed. For every library directory that CA PMO searches that does not contain the member, it adds one to the Member Not Found count. When CA PMO finds the member, it adds one to the Member Found count and the search ends.
Libraries Searched
Library Containing Member
Count for Member Found
Libraries Not Containing Member
Count for Member Not Found
SYS1.LIB1
SYS1.LIB1
1
none
0
SYS1.LIB1 SYS1.LIB2
SYS1.LIB2
1
SYS1.LIB1
1
SYS1.LIB1 SYS1.LIB2 SYS1.LIB3
SYS1.LIB3
1
SYS1.LIB1 SYS1.LIB2
2
member not found
0
3
If LLA is active, CA PMO counts the members as found or not found by the following method:
% Of Total
A breakdown of LNKLST library directory searches into the percentage that CA PMO handled and the percentage it did not handle.
Avg Elap Time
The average time it takes to resolve a LNKLST library directory search:
CA PMO may either estimate averaged elapsed time or actually measure it:
There is one other reason why LLA average elapsed times may be shorter than managed list times. If the more frequently requested members belong to libraries early in the LNKLST concatenation, and the less frequently requested ones are from later libraries, the managed list search times may be divided among fewer libraries. This is because the less frequently requested members may not be in the managed list.
For I/O searches, CA PMO actually measures the elapsed time for each library search:
Elap Time Savings
The elapsed time that CA PMO saved on searches of LNKLST library directories. This figure is the difference between the average elapsed time for managed list searches and the average elapsed time for one of the following:
If you see three asterisks (***), CA PMO did not save any elapsed time.
