The following is how to define your server and port, if you installed with the SMP/E install on USS.
USS (Installed by SMP/E) default:
/cai/om_web_services/utilities
Replace: -Dservername=localhost
With: -Dservername=<servername> (For example: server.company.com)
Note: The server name is the address of the server where you deployed CA OM Web Services.
Replace: -Dport =8080
With: -Dport=<port-number>
Note: The port number is the http or https port of the server where you deployed CA OM Web Services.
