Previous Topic: Retrieving Report DataNext Topic: Instructions for Setting-Up Test Tool (SMP/E based install on USS)
Setup Report Fetch Test Tool
This tool requires you to define your CA OM Web Services server’s URL and port number before running the tool, if you are not running on localhost port 8080. By default, the tool points to a URL of localhost and port 8080.
The server name is the address of the server where you deployed CA OM Web Services. The port is the http or https port of the server where you deployed CA OM Web Services.
Note:
