Previous Topic: Prepare the SMP/E Environment for Pax InstallationNext Topic: Clean Up the USS Directory
Run the Installation Jobs for a Pax Installation
Submit and run these SAMPJCL members in sequence. Do not proceed with any job until the previous job has completed successfully.
Note: The following steps include instructions to execute the [assign the value for hlq in your book]SEDIT macro each time you open a new SAMPJCL member. To edit all SAMPJCL members simultaneously, read and follow the instructions in the [assign the value for hlq in your book]AREAD member, and submit the [assign the value for hlq in your book]EDALL member.
  1. Open the SAMPJCL member DUZ3RECD in an edit session, and execute the DUZSEDIT macro from the command line.
    DUZ4RECD is customized.
  2. Submit DUZ4RECD to receive SMP/E base functions.
    Your product is received and now resides in the global zone.
  3. Open the SAMPJCL member DUZ5APP in an edit session, and execute the DUZSEDIT macro from the command line.
    DUZ5APP is customized.
  4. Submit DUZ5APP to apply SMP/E base functions.
    Your product is applied and now resides in the target libraries.
  5. Open the SAMPJCL member DUZ6ACC in an edit session, and execute the DUZSEDIT macro from the command line.
    DUZ6ACC is customized.
  6. Submit DUZ6ACC to accept SMP/E base functions.
    Your product is accepted and now resides in the distribution libraries.
