Previous Topic: Copy Installation Files to z/OS Data SetsNext Topic: Run the Installation Jobs for a Pax Installation
Prepare the SMP/E Environment for Pax Installation
The members that are used in this procedure prepare the data sets, initialize the zones, and create the DDDEFs for CA OM Web Services.
Before you begin this procedure, confirm whether your product uses UNIX System Services (USS). If it does, establishing a hierarchical file system (HFS) may be required as part of the product installation or required as a feature of the product.
For information about the members, see the comments in the JCL.
  1. Customize the macro DUZSEDIT with your site-specific information and then copy the macro to your SYSPROC location. Replace the rightmost parameters for each ISREDIT CHANGE command. Each time you edit an installation member, type DUZSEDIT on the command line, and press Enter to replace the defaults with your specifications.
    The macro is ready to customize the yourHLQ.SAMPJCL members.
    Note: Set the DASD HLQ to the same value specified for yourHLQ for the unzip to DASD ESD JCL.
    Note: The following steps include instructions to execute the DUZSEDIT macro each time you open a new SAMPJCL member. To edit all SAMPJCL members simultaneously, read and follow the instructions in the DUZEDALL member.
  2. Open the SAMPJCL member DUZ1HOLD in an edit session and execute the DUZSEDIT macro from the command line.
    DUZ1HOLD is customized.
  3. Submit DUZ1HOLD.
    This job produces the following results:
  4. Open the SAMPJCL member DUZ2ALL in an edit session and execute the DUZSEDIT macro from the command line.
    DUZ2ALL is customized.
  5. Submit DUZ2ALL.
  6. If your product requires HFS or if you want to install a feature of the product that requires HFS, complete the following substeps:
    1. Open the SAMPJCL member ccc1ALLU in an edit session and execute the DUZSEDIT macro from the command line.
      Note: All instances of ccc in this section indicate a three-character component code based on the FMID.
      ccc2ALLU is customized.
    2. Submit ccc2ALLU.
      This job allocates your HFS data sets.
    3. Open the SAMPJCL member ccc3MKD in an edit session and execute the DUZSEDIT macro from the command line.
      ccc3MKD is customized.
    4. Submit ccc3MKD.
      This job creates all directories and mounts the file system.
  7. Open the SAMPJCL member DUZ3CSI in an edit session and execute the DUZSEDIT macro from the command line.
    DUZ3CSI is customized.
  8. Submit DUZ3CSI.
  9. If your product requires HFS or if you want to install a feature of the product that requires HFS, complete the following substeps:
    1. Open the SAMPJCL member ccc3CSIU in an edit session and execute the DUZSEDIT macro from the command line.
      ccc3CSIU is customized.
    2. Submit ccc3CSIU.
      This job customizes the CSI by adding the DDDEFs associated with the directory.
