Previous Topic: Migrating InformationNext Topic: Applying Fixes to the Product
Migrate Information
This section describes how to migrate the CA OM Web Services 1.0 repository definitions to the CA OM Web Services 2.0 installation.
Important! It is suggested that you run this step before creating any repository definitions in CA OM Web Services, to avoid overwriting of those definitions.
This process requires your old repository definition file. This file name is rdf.xml.
Note: This file can be renamed or placed in a different location that is based on the following property in the OmWebService.cfg file.
Property:
omWebService.RepositoryDefinitionFile=/config/rdf.xml
Normal File Location:
Unicenter Output Management Web Services\jakarta-tomcat-4.1.24\webapps\caomws\config
Note: For more information, see the CA OM Web Services 1.0 documentation.
  1. Obtain the old rdf.xml file.
  2. Run the Change_CCI_Settings to set up the CCI settings.
    Note: For more information, see Configure CAICCI.
  3. Run Change_License_Server to set up your license server.
    Note: For more information, see Configure the License Server.
  4. Copy the contents of your rdf.xml file into your backup folders rdf.xml file.
    Default Location:
    <CA_OM_Web_Services_Install_Directory>\OM_WS_Config_Backup\rdf.xml
  5. Run Create_RLDD.
    This creates the Report List Data Dictionary that is based on your Repository Definitions.
    Important! Be sure to select Load configuration settings backup location.
    Note: For more information about loading configuration setting from backup location, see Configuration Tool First Steps.
  6. Deploy your WAR/EAR file and continue with other Post-Installation and Configuration Tasks.
