Previous Topic: Uninstall on WindowsNext Topic: Post-Installation and Configuration Tasks
Uninstall on Other Platforms
This section guides you through uninstalling the product on Other Platforms for the InstallAnywhere install.
Note: The SMP/E install does not have an uninstaller. Follow standard SMP/E procedure to remove an SMP/E install.
  1. Navigate to the uninstaller folder.
    <Install Location>\uninstaller
  2. Run the command java -jar uninstaller.jar.
    The uninstaller should start.
    Note: On the USS/Unix/Linux system, you must have the authority to delete the installed files, to run the uninstaller successfully. If you do not have the correct group or user access, be sure to use root or pseudo to run the uninstaller.
  3. Press Enter to continue with the uninstall.
    A Success or Failure message is displayed.
  4. (Optional) Manually delete your configuration backup folder.
    Default:
    <Install Location>\OM_WS_Config_Backup
    Note: Because the Configuration Tool creates the backup folder, not the installer, the uninstaller does not delete it.
