Previous Topic: Launch the UninstallerNext Topic: Uninstall on Other Platforms
Uninstall on Windows
This section guides you through uninstalling the product on the Windows platform.
Note: If an administrator or a different user installed the product, try uninstalling by running the uninstaller as administrator.
  1. Do one of the following:
  2. Do one of the following:
    A Success or Failure message is displayed.
    Note: In case of some failure, certain files may not be deleted and may be listed.
  3. Click Done.
  4. (Optional) Manually delete your configuration backup folder.
    Default:
    <Install Location>\OM_WS_Config_Backup
    Note: Since the Configuration Tool creates this folder, not the installer, the uninstaller does not delete it.
