Previous Topic: Apache TomcatNext Topic: Verify Installation
IBM WebSphere
To deploy the CA OM Web Services, on IBM WebSphere do the following.
  1. Log in to the WebSphere Administration Console.
  2. If deployment is for the first time, then under Applications, select New Application, and then New Enterprise Application. Follow the wizard to create the application, uploading the configure EAR file from the /deployable folder when prompted.
  3. If the application is already deployed and a new EAR must be uploaded for updating either the fixes or configuration changes, then locate the existing application under Application Types -> WebSphere enterprise applications.
    Note: For more information, see the IBM WebSphere product documentation and website.
    Important! If attempting to deploy a WAR file on WebSphere, set class loader order to Classes loaded with local class loader first (parent last), at both application level and module level.
