Post-Installation and Configuration Tasks › Deploy CA OM Web Services › Apache Tomcat
Apache Tomcat
To deploy a WAR file to Apache Tomcat there are two methods.
Method 1: Deploy using the Tomcat Manager
- Log in to the Tomcat Web Application Manager http://yourserver:8080/manager/html) using a web browser.
Note: To define your credentials to the manager application, edit tomcat-users.xml. For more information, see Tomcat documentation.
- In the Tomcat Web Application Manager under Deploy, select or upload the configured WAR file.
- For the Deploy directory or WAR file on the server, fill in the form using the following information:
- Context Path (required): /caomws20
- XML Configuration file URL:
- WAR or Directory URL: install_folder/deployable/caomws20.war
- Click Deploy.
- For the WAR file to deploy, the WAR file must be present on the system where the web browser is run. Browse to the folder containing the configured WAR file, select it, and then click Deploy to upload.
Method 2: Deploy statically to Tomcat
- If Tomcats' server.xml autoDeploy setting is true, then copy the configure WAR file from the /deployable folder into the $CATALINA_BASE/webapps. It is automatically deployed.
- If Tomcats' autoDeploy attribute is false, then extract manually the WAR file into a folder named caomws20 under $CATALINA_BASE/webapps. The manual extraction can be done with the following commands:
cd $CATALINA_BASE/webapps
mkdir caomws20
cd caomws20
jar xf install_folder/deployable/caomws20.war
Note: For more information, see the Apache Tomcat web site http://tomcat.apache.org.
