Previous Topic: Create Application Specific Instance of CCS TomcatNext Topic: Deploy CA OM Web Services
IBM WebSphere Considerations
Ensure that all the fixes for the WebSphere server are applied before deploying the CA OM Web Services on WebSphere.
To run CA OM Web Services on WebSphere with a WAR file, set the Class loader order to Classes loaded with the local class loader first to load libraries within the CA OM Web Viewer package and last for the parent. However, if you selected to produce an EAR file during the installation, then this setting is automatically included in the EAR file, so that you can deploy this EAR file on WebSphere using the default settings.
