Previous Topic: Instructions for Setting-Up Test Tool (InstallAnywhere based install on any platform)Next Topic: Migrating Information
Running the Report Fetch Test Tool
The report fetch tool lets you download a report from a particular repository.
Important! Files that are downloaded to USS are in the ASCII format, and require an ASCII reader, such as z/OS UNIX Directory List Utility (va option).
  1. Open a Command Prompt in Windows or Terminal in Unix/Linux/USS.
  2. Navigate to the Utilities folder.
    Windows Default:
    C:\Program Files\CA\CA_OM_Web_Services\utilities
    Unix/Linux Default:
    /usr/local/CA_OM_Web_Services/utilities
    USS (Installed by SMP/E) default:
    /cai/om_web_services/utilities
    Other:
    <CA OM Web Services Install Location>/utilities
  3. Invoke the Report_Fetch_Test command.
    Note: For more information about how to invoke a program on your platform, see Running the Configuration Tool (Interactive Mode). For Windows, you launch the tool from a command prompt.
  4. Usage and Parameters are:
    Usage:
    Report_Fetch_Test -f {function} -u {userid} -p {password} -r {repositorydefinitionname} -t {reporttypemask} -L {lowerpagenum} -H {upperpagenum} -h {reporthandle} -F {filename} -l {logfilename} -b -o {timeoutvalue}
    Parameters:
    The following are the command parameters for retrieving reports.
    Note: All parameters that include spaces or special characters such as % or $ are enclosed in quotes.
    -f
    Indicates the function the command performs:
    get
    Gets the report.
    help
    Displays command usage help.
    -u
    (Required for get function) Specifies the user ID for the request.
    -p
    Specifies the password for the request.
    -r
    (Required for get function) Specifies a repository definition entry name that identifies the repository where the report is located.
    -t
    Specifies a report type or a report type mask. Report type is the type of the report in the specified repository.
    Report types are:
    TEXT
    For text reports
    AFP
    For AFP reports
    AFPtoPDF
    For report you want to transform to PDF
    Note: The AFPtoPDF option is only valid if the underlying Output Management product supports the AFP to PDF transformation.
    OTHER
    For other report types (will be treated as binary).
    This parameter is required.
    -h
    Required for get function) Specifies the report handle of the report to retrieve. Enclose the report handle in double quotes.
    -L
    Specifies the lower page range for retrieval of a text report.
    If both pageto and pagefrom are omitted, the first five pages of the report are retrieved. If pageto is specified but pagefrom is not, pagefrom is calculated as five pages lower than the pageto value. If pageto is less than five, pagefrom is the first page of the report. If you specify a pagefrom value that is greater than the number of pages in the report, the command returns no data.
    If the report type is not text, this parameter is ignored.
    -H
    Specifies the upper page range for retrieval of text reports.
    If both pageto and pagefrom are omitted, the first five pages of the report are retrieved. If pagefrom is specified but pageto is not, pageto is calculated as five pages higher than the pagefrom value. If the pageto value is greater than the number of pages in the report, the request stops retrieval at the last page of the report.
    -F
    (Required for get function) Specifies the name and path of the report after download.
    -l
    Produces a log file for audit purposes and must be specified with a filename for logging purposes.
    -b
    Backs up the specified file (-F), if the file exists, before overwriting the file for the new request.
    -o
    Specifies the number of milliseconds for the code to wait for a response from the web server.
    Default: 10 seconds
