Previous Topic: Retrieve a List of ReportsNext Topic: Instructions for Setting-Up Test Tool (SMP/E based install on USS)
Setup Report List Test Tool
This tool requires you define your CA OM Web Services servers URL and port number before running the tool, if you are not running on localhost port 8080. By default, the tool points to a URL of localhost and port 8080.
The server name should be the address of the server where you deployed CA OM Web Services. The port is the http or https port of the server where you deployed CA OM Web Services.
Note:
