To address many Web Service connections, CA OM Web Services has a larger connection pool setup in the Web Services configuration file, OmWebService.cfg.
In the configuration file, a larger number must be set for omWebService.MaxConnections and a GROW action must be used for omWebService.MaxAction. You must manually modify this file, to make the required changes.
The default location is <product install location>/OM_WS_Config_Backup/OmWebService.cfg
java -jar <product install location>/utilites/lib/ConfigToolLauncher.jar "CA Output Management Web Services" "<product install location>\deployables\caomws20.war" "ConfigTool.properties" UPDATEWS "<product install location>\OM_WS_Config_Backup\" 2> updateError.log
Note: A success or failure message appears similar to running the configuration tool in interactive mode.
