Previous Topic: Primary Install LogNext Topic: Install Standard Error
Install Standard Out
The install standard out log is placed in:
$USER_TEMP$\ws_install_stdout.txt
Note: The temp folder can be found on the Windows by typing echo %TEMP% in the command prompt. The temp folder on USS/Unix/Linux systems is often /tmp.
