Previous Topic: Log LocationsNext Topic: Install Standard Out
Primary Install Log
The main install log is placed in:
$USER_INSTALL_DIR$\uninstaller\install_update_logs\
Note: If there is a failure early in the installation, or you cancel the installation then the log file is placed in your Home folder in USS/Unix/Linux or in the Desktop on Windows.
The filename for the primary install log is:
CA_Output_Management_Web_Services_2.0_Install_03_22_2013_12_21_57.log
