CA OM Web Services fixes are delivered as SMP/E Maintenance. Fixes can be installed using CA Chorus Software Manager or using SMP JCL.
Note: For more information about applying Fixes, see Apply Preventive Maintenance.
Once all fixes are applied, the CA OM Web Services WAR file must be again configured, and deployed to Apache Tomcat.
If CA OM Web Services is already configured (folder <product install location>/OM_WS_Config_Backup exists), the Update_Refresh.sh utility can be used.
Note: To perform the step you may need SUPERUSER authority. If you don't have the authority, an updated WAR file may be created in a different folder (path will be listed in the output messages).
Once the WAR file is updated, perform the Apache Tomcat deployment. For more information about the deployment, see Apache Tomcat.
