Previous Topic: CA CSM Installation-MainframeNext Topic: Creating Log Information
SMP/E JCL Installation-Mainframe
The following information is required during the installation of the product using SMP/E JCL. This is used when customizing the DUZSEDIT member in the SAMPJCL dataset.
JOBCARD1
Defines the job card information
Default: //JOBNAME JOB (ACCT INFO),'JOB DESC',CLASS=X,
JOBCARD2
Default: //MSGCLASS=X,NOTIFY=,LINES=9999,TIME=1440
JOBCARD3
Default: //*
JOBCARD4
Default: //*
VOLINFO
Edit the SMS VOLINFO statement. If you do not use SMS, comment out the SMS VOLINFO statement and uncomment the statement using VOL=SER, then edit that statement. This information is used when creating the product and SMP/E datasets.
Default: MGMTCLAS=XXXXXXX,STORCLAS=XXXXXXXX,DATACLAS=XXXXXXXX
Alternate: VOL=SER=XXXXXX,UNIT=YYYYYY
CSIVOLINF
Edit the SMS CSIVOLINF statement. If you do not use SMS, comment out the SMS CSIVOLINF statement and uncomment the statement using VOL=SER, then edit that statement. This information is used when creating the CSI VSAM dataset.
Default: MGMTCLAS(XXXXXXX) STORCLAS(XXXXXXXX) DATACLAS(XXXXXXXX)
Alternate: VOLUME(XXXXXX)
GLOBALHLQ
Defines the SMP/E High level qualifier for your GLOBAL ZONE.
Default: CAI
CAIT0HLQ
Defines the SMP/E High level qualifier for your CAIT0 TARGET ZONE.
Default: CAI
PRODHLQ
Defines the Product dataset high level qualifier.
Default: CAI
DASDHLQ
Required if installing from DASD. Defines the high level qualifier that was specified for yourHLQ when the UNZIPJCL job was run.
Default: CAI
SAMPHLQ
Defines the high level qualifier that is used for the SAMPJCL dataset.
Default: CAI
TAPEUNIT
Defines the appropriate tape generic device-type or symbolic group name.
Default: CART
DISKUNIT
Defines the disk unit name.
Default: SYSALLDA
SMPETEMP
Defines the SMP/E Temp File prefix.
Default: CAI
TCPIPDSN
Defines the data set used to obtain parameters that are defined by TCPIP.DATA.
Default: TCPIP_HLQ
EMAILADR
Defines the email address. This value isused for anonymous FTP in order to download the CA HOLDDATA.
Default: EMAIL_ADDRESS
ZNCAIT0
Defines the Target Zone name with in CSI or default to CAIT0
Default: CAIT0
ZNCAID0
Defines the Distribution Zone name within CSI or default to CAID0
Default: CAID0
SMPJHOME
Specifies the IBM Java Runtime Path. This is the location (parent folder) of a pre-existing IBM Java installation. The SMP/E APPLY processing requires the use of applications under this Path (in the /bin folder).
Default: /your/smpjhome/directory/
Example: /sys/java31bt/v6r0m1/usr/lpp/java/J6.0.1/
@pathprefix1@
Defines the top-level USS folder for the target zone elements. This folder must exist, or can be created on, a mounted USS file system. Web Services is installed into this folder.
Default: /cai/om_web_services
Note: This section refers to SMP/E JCL install, not InstallAnywhere install.
