Previous Topic: Installation WorksheetNext Topic: SMP/E JCL Installation-Mainframe
CA CSM Installation-Mainframe
The following information is required during the installation of the product using CA Chorus Software Manager.
SMP/E Environment Name and CSI VSAM Parameters:
Defines the SMP/E environment name.
Example: Web Services production system
Data Sets Prefix
Defines the prefix for the name of the CSI VSAM data set.
Example: CAI.OMWS
Note: .CSI is appended to the prefix value.
Catalog
Defines the name of the SMP/E CSI catalog.
SMP/E Data Sets Allocation Parameters:
High-Level Qualifier
Specifies the high-level qualifier (HLQ) for all SMP/E data sets that are allocated during installation. Product packaging defines the low-level qualifiers (LLQ). The low-level qualifiers cannot be changed.
Example: CAI.OMWS
DSN Type
Specifies the DSN type for allocating SMP/E data sets.
Default: LIBRARY
SMS Parameters (mutually exclusive with Data set Parameters)
Specifies if the SMP/E environment is using SMS parameters.
Storage Class
Defines the SMS storage class for SMP/E data sets.
Management Class
Defines the management class for SMP/E data sets.
Data Class
Defines the data class for SMP/E data sets.
Data set Parameters (mutually exclusive with SMS Parameters)
Specifies if the SMP/E environment is using data set parameters.
VOLSER
Defines the volume serial number to place the data sets. The volume must have enough space for allocating the data sets.
Note: This field is mandatory if you set Catalog to No.
UNIT
Defines the type of the DASD on which to place data sets.
Catalog
Specifies if the SMP/E data set requires to be cataloged.
Target Zone Name and CSI VSAM Parameters:
Target Zone Name
Defines the name for the target zone.
Default: CAIT0
Data Sets Prefix
Defines the prefix for the name of the target zone data set.
Note: This field is only enabled when you have the Create New CSI Data Set check box selected.
Default: Value from the prior panel.
Catalog
Defines the name of the SMP/E target zone catalog.
Target Libraries Allocation Parameters:
High-Level Qualifier Default
Specifies the high-level qualifier (HLQ) for all target zone data sets that are allocated during installation. Product packaging defines the low-level qualifiers (LLQ) and they cannot be changed.
Example: CAI.OMWS
DSN Type
Specifies the DSN type for allocating target zone data sets.
Default: LIBRARY
Specifies if this target zone uses SMS parameters.
Storage Class
Defines the SMS storage class for target zone data sets.
Management Class
Defines the management class for target zone data sets.
Data Class
Defines the data class for target zone data sets.
Specifies if this target zone uses data set parameters.
VOLSER
UNIT
Defines the type of the DASD to place the data sets.
Catalog
Specifies if you want SMP/E data set to be cataloged.
Target Zone Parameters:
Operating System: SMPJHOME
Specifies the IBM Java Runtime Path. This is the location (parent folder) of a pre-existing IBM Java installation. The SMP/E APPLY processing requires the use of applications under this Path (in the /bin folder).
Default: /your/smpjhome/directory/
Example: /sys/java31bt/v6r0m1/usr/lpp/java/J6.0.1/
USS Directory: OUTPUT MANAGEMENT WEB SERVICES
Defines the top-level USS folder for the target zone elements. This folder must exist, or can be created on, a mounted USS file system. Web Services is installed into this folder.
Default: /cai/om_web_services
Note: This refers to a CSM install, not an InstallAnywhere install. For more information about installing with CSM, see How to Install Your Product Using CA CSM.
Distribution Zone Name and CSI VSAM Parameters:
Defines the name for the distribution zone.
Default: CAID0
Data Sets Prefix
Defines the prefix for the name of the distribution zone data set.
Note: This field is enabled only when the Create New CSI Data Set is selected.
Catalog
Defines the name of the SMP/E distribution zone catalog.
Distribution Libraries Allocation Parameters
Specifies the high-level qualifier (HLQ) for all distribution zone data sets that are allocated during installation. Product packaging defines the low-level qualifiers (LLQ) that cannot be changed.
DSN Type
Default: LIBRARY
Storage Class
Management Class
Data Class
VOLSER
Defines the volume serial number on which to place data sets. The volume must have enough space for allocating the data sets.
UNIT
Catalog
