If you plan to use encryption and digital certificates for communications between CA Performance Center and the IdP, a properties file is required. In this file, you specify the certificate to use for signing and encryption and other parameters to enable the encryption.
The SAML properties file is saved in the Single Sign-On home directory:
/opt/CA/PerformanceCenter/sso/webapps/sso
For example, a file like this is required:
/opt/CA/PerformanceCenter/sso/webapps/sso/configuration/ saml.properties
The properties file must include the following parameters:
Here is an example of the syntax:
# Location of the certificate used for signing SAML documents saml.sp.certificate.location=/opt/CA/saml2configuration/[Certificate filename] saml.sp.certificate.password=[password] saml.sp.certificate.alias=[alias] saml.sp.metadata.hostname=[Full Hostname of CA Performance Center server] saml.sp.metadata.entityID=[Name of the CA Performance Center server without IP domain] saml.sp.metadata.organizationName=[Name of your organization] saml.sp.metadata.contactPerson=[First and last name of administrator] saml.sp.metadata.email=[Email address of contact person] # Location of the metadata file for the Login Site saml.idp.metadata.file=/opt/CA/saml2configuration/[Filename].xml # Session timeout with the IdP in minutes. Use this value for auto-reauthentication and logout requests saml.idp.sessionTimeout=[Length of timeout period in minutes]
Whenever you modify the saml.properties file, export the metadata file (which establishes the agreement with the IdP) again. For more information, see Configure SAML 2.0 Support in Single Sign-On. You must also restart Single Sign-On.
