Setting Up SAML 2.0 Support › How to Set Up SAML Authentication
To enable SAML 2.0 authentication in Single Sign-On, the administrator must perform the following procedures:
- Following the guidelines specific to the Identity Provider (IdP), create a metadata file that establishes the agreement between the IdP and Single Sign-On.
For more information, see Prepare the IdP Agreement.
- (Optional) Create a properties file to enable digital signatures and encryption for communications between the IdP and servers running CA software.
For more information, see Preparing the Security Properties File.
- Use the Single Sign-On Configuration Tool to set parameters for SAML Authentication.
For more information, see Configure SAML Support in Single Sign-On.
- Set parameters on the IdP server. For example, add all data source product websites that support SAML to the list of trusted sites.
For more information, see Configure the IdP.
- Update user accounts in CA Performance Center Administration to add an instruction to use external authentication.
For more information, see Complete SAML Setup.
