IP domains are required for monitoring multiple environments with overlapping IP addresses. Set up all the domains that you need before you begin to export flow data.
The Manage IP Domains page opens and displays the current domains.
The current domains are shown under All Domains. To display the parameters for a domain in CA NetQoS Performance Center, select the domain and click the Properties tab.
If you have not created any custom IP domains, only the Default Domain appears in the list. This predefined domain has a 'null' setting for all parameters.
Any custom domains that you have created include values for the following parameters:
Identifies the domain.
(Optional) Describes this domain namespace, such as naming the enterprise that owns it.
Is the IP address of the primary name server for this domain.
Is the port number that the primary name server uses.
Is the IP address of the secondary name server for this domain. Can be the same as the primary address.
Is the port number that the secondary name server uses.
