You can add a complete set of default NBAR2 application mapping rules in a batch import operation. You perform this task on the command line by using the nbar2.csv file that comes with the product.
Note: The NBAR2 application mapping rules that you import represent the current set of NBAR2 application definitions as of the product release time frame.
cd <install_path>\reporter\racmd
where:
<install_path> is the product installation path. The default path is C:\CA\NFA.
racmd is the directory that contains the nbar2.csv file. The file is written to this directory when you install the product.
racmd -import nbar2.csv
where:
nbar2.csv is the name of the application mapping rule file that you want to import. The command string is based on the expectation that the racmd command and .csv file are in their default location. If you have moved the .csv file, include the fully qualified path (the path and file name).
If any errors occur during the import, error messages are shown. If no message is returned, the import succeeded with no problems.
The Application Definitions page opens. The new rules are shown in the Application Definitions page list.
By default, each NBAR2 application is mapped to a separate port. The default ports are above 65000.
Reports use this name to label the combined traffic.
If you update a rule name, all rules that use that destination port are renamed to match the new definition. The rule name and label is set when you edit the final rule name.
