This topic describes some of the error messages that may be displayed. When importing is complete, the command returns error messages for any failed imports, then lists the fields for the failed rules.
If the rule import file contains column definition errors, the import operation fails. If the file contains errors in rule definitions, the import operation skips each faulty rule and continues with the next rule.
Notes about the Description field:
The import file contains a duplicate of the column named in the error message. The column name is shown in place of 'XXX'.
Troubleshooting: Delete the duplicated column. Follow the format in the appropriate example file as described in Import Custom Application Mapping Rules.
One of the following problems occurred while you were updating existing rules:
Troubleshooting: Verify that the appID is entered correctly and that its rule still exists. You can export the current rules to a .csv file as described in Import Application Mapping Rule Updates. The export file includes the appIDs for all of the current rules.
Both of the following conditions were met:
Troubleshooting: If this error occurs rarely, you may want to edit the rules individually on the Application Definitions page. To update a group of existing rules by using the racmd command, use the import file format that is described in Import Application Mapping Rule Updates.
The import file may have a misspelled column name or may include an invalid column. This error may also occur if a rule has an invalid value for a required field (a field other than desc).
Troubleshooting: Verify that the following elements are correct in the import file:
The error may occur if either of the following conditions is met:
Troubleshooting: Add the missing value to the rule definition.
The Subnet rule has an unsupported Mask value.
Troubleshooting: Specify a Mask value between 0 and 32.
The All (ToS) rule has an unsupported ToS value.
Troubleshooting: Specify a ToS value between 0 (all ToS) and 255.
The rule has no specified value for one of the required fields.
Troubleshooting: Verify that all of the required field values are included. All field values are required except for desc.
To display help for the command, enter:
setapplicationmapping
