You can delete a router on the Active Interfaces page, but leave it in place on the Available Interfaces page. For example, you may want to delete a router in this way to address capacity issues. Later, you can restore the router (but not its historical data) by enabling its interfaces on the Available Interfaces page.
Deleting a router removes its interfaces, CVIs, 15-minute (historical) data, and traps. The deletion also affects any related aggregations, views, and reports.
Note: If you delete the router from the Available Interfaces page, the system has no further record of the router.
The Available Interfaces page opens.
You can select and disable multiple routers simultaneously provided the selections are on the same page.
A confirmation message opens.
The Enabled status for the interfaces changes to 'No.' New data from the interfaces is no longer collected or shown in reports. Data that is already collected is still available for reports.
The Active Interfaces page opens.
The following events result:
Note: A router that you delete from the Active Interfaces page reappears if the router interfaces are enabled on the Available Interfaces page and the interfaces begin to send flow again.
