Previous Topic: Working with Interfaces and RoutersNext Topic: Search for a Router or Interface
Active Interfaces Page
Use the Active Interfaces page to view the routers, interfaces, custom virtual interfaces (CVIs), and interface aggregations.The page shows only the routers and interfaces that have contributed to the collected data at some time. You can perform the following actions on the Active Interfaces page:
  1. Open the Active Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select Interfaces: Physical & Virtual from the Administration menu.
      The Active Interfaces page opens.
The Active Interfaces page includes the following options:
Search
Use a text string to search for routers, interfaces, or other elements with a matching address or name.
Edit
Modify properties of the selected item or items.
Delete
Remove routers and interfaces from the page--for example, to address capacity issues.
Merge
Combine the data for two selected physical interfaces or CVIs.
Add Custom Virtual Interface
Create a custom virtual interface based on the selected physical interface.
Active Interfaces: Router Information
Routers are listed in tables on the Active Interfaces page. The router tables contain the following columns.
Flow Status Click the Edit icon to change view settings. Click the Edit icon to change view settings.
Status of the router at the most recent scheduled polling attempt:
Router Address
IP address of the router
Router Name
User-assigned name of the router, such as lab1 router
Template
Interface naming template that is assigned
Interfaces
Total number of interfaces, interface aggregations, and CVIs for the router. This count includes only the interfaces that have contributed to the collected data at some time. To review all interfaces, go to the Available Interfaces page.
Harvester
IP address of the Harvester that collects data from the router
Active Interfaces: Interface Information
Interfaces and custom virtual interfaces (CVIs) are listed on the Active Interfaces page in tables nested under their parent routers. To display the interfaces and CVIs for a router, click the arrow next to the router name. Interface tables contain the following columns.
Traffic Status Click the Edit icon to change view settings. Click the Edit icon to change view settings.
Status of the interface at the most recent poll:
Class
Icon for the interface type, such as a physical interface, CVI, or interface aggregation. To display the interface type name, position the cursor over the icon.
Interface Name
User-assigned name of the interface, CVI, or interface aggregation
Description
Optional information for identification
If Index
Index value, which is assigned by the device that sends flows to the interface
Type
Connection type, such as WAN or LAN
In Speed
Inbound speed of the interface, provided the speed is known
Out Speed
Outbound speed of the interface, provided the speed is known
Domain
Domain of the interface. If the environment has only one domain, the Domain column is not visible.
Notes
Link to add, edit, or view notes about an interface. If the note is empty, the Notes icon is dimmed. For example, you could add information about the time zone, business unit, geographical location, alternate bandwidth, circuit ID, or history. Notes icons are dimmed until they are populated and the page is refreshed.
To display the Notes icon, set the Display Notes Field value to True on the Application Settings page.
