Custom Reports › Set Up Custom Reports
Depending on your user account settings, you may be able to perform a number of actions for Custom Reports:
- View existing reports that have been run.
- Run existing report definitions on demand.
- Set up a schedule for running and sending reports by email (Typically for Administrators and Power Users only).
- Create a Custom Report by stepping through the Custom Report wizard.
- Create a Custom Report by using an existing report as a starting point.
- Make changes to the following parts of an existing report definition:
- Report name, parent folder, and description
- Report summary types: interface, ToS, protocol, host, and conversation
- Presentation views used for the summary data
- Reporting period, data resolution, and time filter
- Report recurrence schedule and email recipients
- Set the following elements to be included or excluded as report data sources:
- Interfaces or interface groups
- Protocols and ToS values
- A host and subnet
- A conversation
- A subnet mask for aggregating data
This section contains the following topics:
Review Settings for Custom Reports
Customize Which Interfaces Are in Custom Reports
Specify Custom Report Filters
Define Custom Report Periods and Schedules
View Custom Reports
