You can locate and select an interface by using the Group tab in the Interface Index. The Group tab shows the groups organized in a tree. The tree can help you locate a specific interface, especially when in an enterprise that has large numbers of routers and interfaces.
Note: The Group tab appears only if the product is registered as a data source for Performance Center. If the product is not registered, the Interface tab appears in place of the Group tab.
The Interfaces page opens and shows the Interface Index. This is the first page that you see when you log in to the NFA console.
The group tree is displayed in the left pane.
To expand the contents of a high-level group, click its arrow icon. For example, you could click the Inventory group or expand the Inventory group and select a domain sub-group.
If the selected group or its sub-groups contain interfaces, the list of the interfaces opens in the right pane.
An Interface Overview report page opens, which displays data for the selected interface.
The Presentation menu opens.
Interface Tab
The Interface tab displays a list of the available interfaces in an alphanumerically sorted list. By default, 10 interfaces are shown on each page. To re-sort the table data, click a column heading.
