Interface Reports › Open Interface Reports › Use the Interface Index › Open an Interface Report: Router Tab
You can use the Router tab in the Interface Index to locate an interface by router. The Interface Index shows the available routers in an alphanumerically sorted list. By default, 20 routers are shown on each page of the list.
- Select Interfaces in the NFA console menu.
The Interfaces page opens and shows the Interface Index.
- Make sure the Router tab is displayed.
- Locate the interface that interests you. Use any of the following options to locate the interface:
- Click the name of the parent router to expand a list of its interfaces.
- Search: Search for whole or partial text strings. Searching filters the list to show only the entries that have an Interface or Description column value that matches your search term.
- Max per Page: Change the Max per Page setting to show more routers and interfaces on each page.
- Click the interface that interests you.
An Interface Overview report page opens, which displays data for the selected interface.
- (Optional) Change the format or type of data displayed in the report:
- Click the gray bar on the left.
The Presentation menu opens.
- Select the desired display and metric options, as described in Set the Presentation Options.
- (Optional) Click the bar again to hide the menu.
