Installation and Upgrade › Installation and Upgrade Prerequisites › Back Up the Databases and Restart the Services
Before you upgrade, back up the databases and files that are listed in the following table.
Important:
- Run backups concurrently. If you restore data from backups that have different timestamps, problems can result. Ensure that your backed-up data files are timestamped with the same hour.
- Store backups to a remote location to guard against the possibility of a hardware or operating system failure on the main server. For example, back up the databases to an administrative share or mapped network drive.
- Log in as a user who has administrator privileges for the product.
- Connect to the server:
- Open a Remote Desktop session.
- Initiate a Terminal Services or VNC session to the installation server.
- Copy each target directory and file to a remote location.
- Restart the services.
