You must add an instance of CA Network Flow Analysis for CA Anomaly Detector to monitor. You also have the option to add any other products that you want to monitor for anomalies. This topic describes how to complete this task in a CA Performance Center deployment.
The Anomaly Detector page opens in the NFA console.
The Add Monitored Product dialog opens.
Select the product name from the list: CA Network Flow Analysis.
If CA Network Flow Analysis is not listed, verify that you have not already registered a CA Network Flow Analysis instance as a monitored product. You can register only one instance of CA Network Flow Analysis to a single instance of CA Anomaly Detector.
Enter the IP address of the CA Network Flow Analysis server.
The Anomaly Detector page shows the NFA console that you added. All of the currently configured Harvesters are added as potential data collectors on the Collection Sources tab, but the Harvesters are not enabled at this point.
The list of monitored products page reflects your changes. CA Anomaly Detector contacts the product to add the collection sources to the View Collection Sources tab.
