Previous Topic: Hardware SpecificationsNext Topic: Co-Installation
Software Compatibility
CA Network Flow Analysis 9.3.0 runs with CA Anomaly Detector 9.3.0, but not with previous versions of CA Anomaly Detector. Upgrade any previous version of CA Anomaly Detector that is currently installed.
CA Anomaly Detector requires that certain software is installed in your environment. The following table describes which software versions are supported:
Program
Supported Version
Required?
CA Anomaly Detector installation that you intend to upgrade *
9.2.1
Required for upgrades
CA Performance Center
2.4/2.3
Required in a deployment that includes CA Performance Center
CA NetQoS Performance Center
6.1.205 SP2/6.1.194
Required in a deployment that includes CA NetQoS Performance Center
CA Network Flow Analysis (1 instance)
9.3.0
Required to enable AD 9.3.0 operation
CA NetVoyant (1-2 instances)
7.1 SP7
Optional data source for anomaly monitoring
CA Application Delivery Analysis (SuperAgent) (1-2 instances)
10.1
CA Unified Communications Monitor (1-2 instances)
3.7
* If your pre-upgrade CA Anomaly Detector version is earlier than 9.2.1, upgrade to version 9.2.1 before you begin.
