Previous Topic: Register CA Anomaly DetectorNext Topic: Add Products to Monitor
Enable Configuration in the NFA Console
If your deployment includes CA Performance Center, you use the NFA console to perform administration tasks for CA Anomaly Detector. Skip this task if your deployment includes CA NetQoS Performance Center.
  1. Log in to the NFA console as a user with administrator privileges, if you are not already logged in.
  2. Click Administration.
  3. Click Anomaly Detector in the menu pane.
    The Anomaly Detector page opens with the View Monitored Products page displayed.
  4. Click Add/Edit Anomaly Detector.
    The Add/Edit Anomaly Detector dialog opens.
  5. Select values for the following options:
  6. Click Save.
    You return to the Anomaly Detector page. The configuration options are now enabled, so you can add products for CA Anomaly Detector to monitor.
