To display CA Anomaly Detector data in views, you must add CA Anomaly Detector as a data source for Performance Center.
The page for managing data sources opens: Manage Data Sources (CA PC) or Data Source List (NPC).
The dialog for adding a data source opens.
All related products and selected third-party integrations are listed in the Source Type list regardless of whether they are installed in your environment. If a data source type is not listed, check to see if you have already registered the maximum number of data sources for that type.
Select https if your network uses SSL for communications. If you select the https option, verify that you have configured the system correctly for https access. For more information, see the Single Sign-on User Guide.
The port you specify depends on the protocol you select. The recommended port for the http protocol is 80. The recommended port for the https protocol is 443. If you plan to use SSL for communication with Performance Center, see the Single Sign-on User Guide.
The default setting is for the Web Console address to be the same as the Host Name.
If you do not specify a name, a default name is generated automatically. The default name consists of the data source type combined with the host name. For example, you can specify AnomalyDetector_London as the Display Name in place of a default name like AnomalyDetector@xxx.x.x.xx.
If the connection fails, verify that the server name or IP address is accurate for the source type. If the connection fails again, contact CA Support.
You return to the main page, which shows CA Anomaly Detector in the list of data sources.
