Previous Topic: Probability ThresholdsNext Topic: Absolute Thresholds
White List
Use the White List to exclude servers from monitoring and from views when you edit a sensor configuration. The White List typically consists of hosts that are known to be safe.
Do not add a host to the White List if the host is important and the host may be vulnerable to attack. For example, do not add DNS servers to the White List even though these servers may generate spurious anomalies. As CA Anomaly Detector continues to gather data about typical behavior, it should create fewer spurious anomalies for hosts like DNS servers.
