Previous Topic: Absolute ThresholdsNext Topic: Configure Alert Targets
Configure Sensor Thresholds and Options
You can configure sensors to have different probability thresholds and to include the following optional features: absolute thresholds, alerts, and host exclusions.
  1. Display the Data Source List page:
    1. Log in to the Performance Center Console as a user with administrator privileges, if you are not already logged in.
    2. Select Admin, Data Sources.
      The page for managing data sources opens: Manage Data Sources (CA PC) or Data Source List (NPC).
  2. Click the name of the CA Anomaly Detector instance that you want to configure.
    The Monitored Products page opens.
  3. Click View Sensors.
    The Sensors page opens and displays the first group of sensors. Click the page numbers at the bottom to page through the sensor list.
  4. Double-click the row for the sensor that you want to edit.
    The Edit Sensor page opens.
  5. Edit any of the following options that you want to change:
  6. Close the Edit Sensor page: Click Save or Cancel.
    You return to the Sensors page, which reflects any changes that you saved.
