CA Network Flow Analysis provides information to help you understand how application traffic affects your network performance. CA Network Flow Analysis enables you to see which applications are using bandwidth, who is using the bandwidth, and when. This knowledge helps you can timely and cost-effective decisions to optimize network performance.
When you add CA Network Flow Analysis as a data source for Performance Center, the Harvesters are added automatically as possible data sources for CA Anomaly Detector. Special considerations apply when you enable Harvesters as data sources, as described in Best Practices: Slow Harvester Rollout.
