The RST-Only Sources sensor looks for the following types of connections:
Troubleshooting an RST-Only Sources Alert
An alert from the RST-Only Sources sensor may indicate one of the following issues:
Investigate whether a server upgrade is needed.
Try restarting associated application services.
Check for DNS issues and correct any issues that you find.
Identify and use the firewall or ACL to block the offending host from sending data on the network while you investigate.
