Previous Topic: Operating System SupportNext Topic: Software Compatibility
Hardware Specifications
We tested the product with the following hardware configuration. Your requirements may vary depending on the characteristics and volume of interfaces, applications, and operators in your network.
Note: The recommended specifications represent the configuration of CA appliances that are currently shipping. You can run CA Anomaly Detector successfully if your configuration does not meet these specifications, although your performance may vary. You can also run CA Anomaly Detector on a configuration that exceeds these specifications.
System Specifications for CA Anomaly Detector installed stand-alone or co-installed with CA Network Flow Analysis:
