Previous Topic: Get Started with CA Anomaly DetectorNext Topic: Probability Thresholds
Features and Benefits
CA Anomaly Detector goes beyond intrusion detection and other more static security tools to take a broader view of the network. The program can monitor your entire network from end to end. Instead of painstakingly applying a fixed set of rules to traffic, CA Anomaly Detector uses a set of dynamic algorithms to create and continually modify a unique profile of the network. The program uses this profile in combination with efficient mathematical analysis to determine whether network traffic is anomalous.
In addition to detecting suspicious or damaged packets, CA Anomaly Detector identifies abnormally high flow and volume sources that can indicate a variety of issues. The program easily scales to create integrated monitoring and reporting across your enterprise. You receive alerts about potential problems, such as:
Operating in real time, the program identifies fan-out, SYN-only, and ICMP flood traffic that usually indicates a spreading virus, worm, or port-scanning activity. The program also alerts you to:
The program reports only the essential data you need to secure your system and stop intrusions, other security issues, and performance problems. Report views are shown in the Performance Center Console, where they contribute to an enterprise-wide perspective on network performance and health.
CA Anomaly Detector provides the following benefits:
