Previous Topic: Disable Unneeded Windows ServicesNext Topic: Uninstallation Prerequisites
Uninstalling the Software
The CA Network Flow Analysis 9.2.1 includes an option to uninstall the product, which you can use to remove CA Network Flow Analysis after an installation or upgrade.
Notes:
Important! Do not use the Uninstall option if you have upgraded from CA NetQoS ReporterAnalyzer 9.0.1.
This section contains the following topics:
Uninstall the Software
