Valid on Console, Harvester, or DSA
When I click Next in the License Agreement screen of the installation or upgrade program, an error message opens, which begins with the following text:
"sc.exe is not installed. The installer was unable to find "sc.exe" in the System32 folder."
A system check did not find the Service Control command (the sc.exe file) in the Windows/System32 directory. The Service Control command is used for communicating with the Service Controller during command line operations. If the file is missing, the installation or upgrade program exits.
The sc.exe file is included with the Windows Server software by default. To correct the problem, restore the missing sc.exe from your Windows Server installation software, Windows Resource Kit, or other resource.
Copyright © 2014 CA.
