Previous Topic: View a List of MenusNext Topic: Add a Menu
Custom Menus
Administrators and designers can create custom menus for the Dashboards tab (CA PC) or Reports tab (NPC). Custom menus let you determine which dashboards are available to each user account. For example, an operator might log in and see three or four menus of dashboards. The menus can be configured sot that the operators see only the data that they require.
If your user account has the necessary role right, you also can create custom dashboards to populate a custom menu.
Custom dashboards that are in a user’s My Dashboards (CA PC) or My Reports (NPC) menu are not visible to other users. Users can therefore copy a dashboard from a factory menu to their My Dashboards or My Reports menu and customize it.
A custom menu is not available to any users until the administrator edits a role to include it. The role must, in turn, be assigned to a user account.
