You can change the time frame for a dashboard or Interface page that you are viewing. Change the time frame to see data from an earlier time of day or from another date, for example
Changing the time frame is useful for troubleshooting performance issues. For example, if data from the past day contains an anomaly, you can change the time frame to show data from the last seven days. The time frame helps you determine whether the issue occurs repeatedly.
When you change the time frame for a dashboard or Interface page, it is applied to all views on the page, and to all dashboards in that window. You can view dashboards in multiple windows and can apply a different time frame to each dashboard, however.
Lets you select a predefined time frame for the data.
Default: Last Hour.
Shifts the time frame for the data back by one increment of the present interval (such as Last Day or Last Hour).
Let you select a start and end date for the data from a calendar view.
Let you select a start and end time from a list of 15-minute time intervals in the 24-hour format.
Shifts the time frame for the data forward by one increment of the present interval (such as Last Day or Last Hour).
The data in the views reflects the new time frame.
If you are viewing data for the last day, click the left arrow to scroll back in time by one day. Or click Latest to see the most recently collected data.
Copyright © 2014 CA.
