The icons at the top of each dashboard or view page give you access to time frame settings and other options for all of the views. The icons in the title bar of each view let you modify view settings, export views, and access Help.
You can select predefined or custom time frames for dashboards. The time frame setting affects all of the views on the page.
Copyright © 2014 CA.
