This topic describes view options in the CA Performance Center Console.
Many views offer a search feature and other settings that you can change to modify the view. In addition to filtering and time frame options, the following options are available for most data views:
Note: Users with the 'Save Changes to Shared Views' role right can save view modifications to their own user account. The changes persist after logout. However, other users cannot see changes to views.
Other view options are specific to the selected view. The available options depend on the format and data source.
The trend views that are available in context pages let you quickly and easily change the trend lines that are displayed on the graph. The following options also apply to multitrend views:
Trend views also include an option to add a "goal line" as a visual indication of performance levels or thresholds. You can supply any value or label for the goal line, and you can show or hide the goal line for a selected trend view.
In table views, you can drill down to detailed data for individual items. Use the page feature to see metrics from a longer list of items. Increase the Max Per Page value to increase the size of the view and the number of table rows per page.
You can sort table data columns by selected metrics and also select columns to include. Click a table column to sort. A white arrow on the column lets you access a menu of table column options. Select Columns to enable and disable the metrics that were enabled for the table by default.
The browser view is a unique view type that lets you add a URL to a selected report page. You can use this view to compare external factors alongside your network performance views. Also, the browser view lets you update internal and external data dynamically. The URL must be for a web page that supports embedded iframes.
Multiple external factors can affect the performance of your network and servers, such as world events and adverse weather conditions. The ability to view a weather map and news headlines alongside performance data views on a single report page can help you better understand patterns in network performance.
When a view does not display CA Infrastructure Manager Data Aggregator data, this option lets you drill down directly to the CA Infrastructure Manager Data Aggregator Admin page to troubleshoot monitored devices and items.
Copyright © 2014 CA.
