You can change the context for some individual views on a dashboard. Change the context of an enterprise-wide view to show data from a different set of managed items. Change the context of an interface-specific view in the CA Performance Center Console to show data from a different interface.
Changing the view context can be useful for troubleshooting. You can compare data from different locations, for example.
The settings dialog opens.
If the settings dialog does not contain a 'Filter by' option, you cannot change the context for the view.
The context types that are available depend on the type of view.
Note: The availability of these options depends on your user account role rights.
The view is updated to show data from the new context.
You can also change the context for a custom dashboard, which applies the selected group or managed item as a filter to all views on the page.
Copyright © 2014 CA.
