Making Additional Customizations › Set Up Application Mapping › Create an All (ToS) Application Mapping Rule
Create an All application mapping rule to combine, separate, or more clearly identify traffic by its ToS (Type of Service) value.
- Open the Application Definitions page:
- Select Administration from the NFA console menu.
- Select Application Definitions in the Administration menu.
The Application Definitions page opens.
- Verify that Application Mapping is the selected value for Rules.
- Click Add Rule.
The Add Application Mapping dialog opens.
- Select All from the list of rule types at the top of the dialog.
The Add Application Mapping dialog switches to All (ToS) rule mode.
- Specify the setting values:
- ToS: Type of Service (ToS) to use as a filter for the collected data.
ALL is the ToS value that is shown initially when you open the dialog. If left unchanged, this setting would map traffic for all ToS values to the destination port.
- Destination Port: Target port that collects the mapped data
If you specify a destination port that is already used by other rules, the traffic for the related rules will be combined.
- (Optional) Click Check to run a general check to detect whether the specified port is already receiving data. The check fails if the port is receiving native data--that is, data that is not mapped by application mapping rules. If any native data is on the specified destination port, that data is redirected to the rebase port.
- Name: Identifier for the rule as it is listed on the Application Definitions page
The rule name also is the label for the mapped traffic in certain reports. If other rules map traffic to the same destination port that you specify for this rule, specify the name that you want to use for the combined traffic.
- Description: (Optional) Additional descriptive text to identify the rule type and its use, which is displayed only on the Application Definitions page
- Click Save.
The dialog closes. The new rule is added to the Application Mapping rule list. If any other rules map traffic to the same port and you specified a new rule name, the other rule names are updated.
- (Optional) Run reports to verify that the traffic on the designated destination port fits the rule.
- (Optional) Review the effects of the new or changed application mapping rules on reports, then consider renaming the rule to label the mapped traffic more clearly in reports.
Copyright © 2014 CA.
