Previous Topic: Create an All (ToS) Application Mapping RuleNext Topic: Create a Subnet Application Mapping Rule
Create a Host Application Mapping Rule
Create a Host application mapping rule to combine, separate, or identify traffic based on its source host. For example, a Host application mapping rule can report the total traffic from a particular server or from an application on the server.
  1. Open the Application Definitions page:
    1. Select Administration from the NFA console menu.
    2. Select Application Definitions in the Administration menu.
    The Application Definitions page opens.
  2. Verify that Application Mapping is the selected value for Rules.
  3. Click Add Rule.
    The Add Application Mapping dialog opens.
  4. Select Host from the list of rule types at the top of the dialog.
    The Add Application Mapping dialog switches to Host rule mode.
  5. Specify values for the following settings:
  6. Click Save.
    The dialog closes. The new rule is added to the Application Mapping rule list. If any other rules map traffic to the same port and you specified a new rule name, the other rule names are updated.
  7. (Optional) Run reports to verify that the traffic on the designated destination port fits the rule.
  8. (Optional) Review the effects of the new or changed application mapping rules on reports, then consider renaming the rule to label the mapped traffic more clearly in reports.
